Which brakes would be better?
Car: 1992 RS
Engine: 406 Stealth Ram
Wilwood Heavy Duty Kit (650 bucks new): 4 piston Wilwood Dynalite caliper, aluminum hub, 2 piece rotor (12"x.81")
or
C5 Brakes (gonna cost over 400 if I cant find good used parts): 2 Piston PBR Caliper, Cast Iron 3rd gen rotor as hub, C5 rotor (12.8"x1.25").
The thing that turns me off of the Wilwoods is the small caliper size, but the 4 pistons sounds great, and so does having a lightweight aluminum hub and 2-piece rotor assembly. Any comments, suggestions? Thanks!
Scott
or
Scott
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Wilwood recommends that "Heavy Duty" kit as drag race set-up. That's also why the calipers are small. If you plan to do any kind of "spirited" driving either on the street or auto-x...etc, they'll tell you NOT to use their kit. At .81 their rotors are also on the thin side for street use.
The C5 brakes would be the better way to go if you plan to canyon carve, auto-x...and so on.
Car: 1992 RS
Thanks for the info. The auction is above what I was willing to pay now anyway, so its a no-go for me. If anyone's interested, check out http://cgi.ebay.com/ebaymotors/ws/eB...em=2416294548. I guess it back to plan A again, C5 brakes
dbrochard
Sep 19, 2015 08:13 PM
