Edelbrock strut tower brace for tbi
Old May 27, 2003 | 12:49 PM
Graboid's Avatar
hmmm,
i just received the piece and i assembled it to check if all parts are there or not. It looks complete. But i have a question to the ones of you who have the part installed. I noticed that the diameter of the bolts which hold the main brace to the support brackets is smaller than the hole in the brace. That gives the brace room to move around unless one tightens the nuts. My idea of a towerbrace is that it is a stiff piece. Will the tightened nuts put enough pressure against the bracket that the brace can't move?
And by the way, sorry for my crappy english...
Old May 27, 2003 | 12:55 PM
v8unleashed's Avatar
once you tighten it down it doesn't move.....
Old May 27, 2003 | 12:57 PM
Graboid's Avatar
Did you feel an improvement?
Old May 27, 2003 | 01:03 PM
nope....
but it looks cool and makes it hard to put in oil
Old May 27, 2003 | 01:05 PM
uk89camaro's Avatar
damn tight! it works too!
Attached Thumbnails Edelbrock strut tower brace for tbi-stb-chrome-air-pan.jpg
Old May 27, 2003 | 02:39 PM
Graboid's Avatar
I don't expect a big difference. Last week i installed SFC's and i can feel an improvement but i won't call it a big one....but since the dang convertibles flex so much i suppose i should do everything to stiffen the chassis....
Old May 27, 2003 | 06:08 PM
Pepsicola's Avatar
Engine: 305 TBI
Transmission: 5 spd
Axle/Gears: 10 bolt w/eaton posi 3.73
When I put mine in I felt a little bit of a difference. I want to get a wonder bar to to really stiffen this up.
Old May 29, 2003 | 03:55 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
Yes they work. This is the first thing I did and I instantly felt the difference. Then I installed my SFCs and "WOW" a new car.... I've just received my wonderbar which I will install once I get back from Spain vacation
Old May 29, 2003 | 09:41 AM
uk89camaro's Avatar
Adding my STB improved handling by 100%. Funny bar after that another 20%. Great fun to drive now.
Old May 29, 2003 | 09:45 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
whats a funny bar?
BTW back to the STB, you will be fine, the point of the brace is to keep the strut towers equal distance apart from each other, even with those bolts not tightened all that much, it will do that.
Old May 29, 2003 | 10:05 AM
uk89camaro's Avatar
Originally posted by Dewey316
whats a funny bar?
Funny bar does a similar job to the STB, but it's mounted under the car, where the anti-roll bar is attached behind the radiator. I believe they came as an option on some IROC/Z28's.
Old May 29, 2003 | 10:12 AM
Dewey316's Avatar
Car: 1990 Camaro RS
you mean wonder bar.
gotcha.
Old May 29, 2003 | 10:16 AM
uk89camaro's Avatar
Dunno why funny bar popped into my head Yeah the steering box brace, wonder bra thingy.
Old May 29, 2003 | 10:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
for a minute there i thought you had some special secret LOL
Old May 29, 2003 | 10:01 PM
25THRSS's Avatar
Is spohn gonna be making one any time soon?
Old May 30, 2003 | 06:42 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
You know why they call it a wonder bra, don't ya? Cause when the woman takes it off, all the guys wonder where her **** went.
(This might be a wonder post for me. As in....I wonder if I'm gonna get banned... )
Old May 30, 2003 | 11:18 AM
Graboid's Avatar
Installed the piece today. I have to say it ROCKS! Front end is stiffer now and 60 percent of the dashboard noises are gone. If you have a convertible, i suggest you go and get one asap.
Old May 31, 2003 | 12:43 AM
Spdfrk1990's Avatar
i was needing to install a stb but i want to switch engines later to i dunno if i should wait or what. Cause dont the tpi and tbi use to different braces i really want 1 now lol.
Old Aug 24, 2003 | 05:17 PM
Tibey's Avatar
Car: 1987 Chevy Camaro Z28
Engine: 305, 4bbl, A/C, T-Tops
Transmission: 700R4 4speed Automatic
I bought one (Edelbrock Strut Tower Brace for TBI/carb.) but in the rush to get it I didn't check that it wouldn't fit on cars with the A/C on the driver's side... does any one want to buy it? $120 takes it!
Old Aug 24, 2003 | 06:16 PM
whoever you bought it from will probably swap it for you
Bubbajones_ya
Jul 6, 2024 08:32 PM
toronto formula
Sep 10, 2015 07:31 AM
lock1983
Brakes
Sep 9, 2015 09:08 PM
89 formula TPI
Sep 8, 2015 08:00 PM
Ian Irvine
Sep 4, 2015 08:08 AM
