Master cylinder & proportioning valve interchange.
Old May 27, 2003 | 06:57 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Here is what I have, 1 master cylinder and prop. valve from an '86 TA with 4 wheel disks (donor car). 1 master cylinder and prop. valve from an '88 Formula also with 4 wheel disks. From what I've read both the master cylinder and prop. valve should be able to work on either car, right? I ask because both should be rebuilt and one is aluminum and the other is rusted iron.
Also, what would happen if the prop. valve went bad? Thanks in advance.
Old May 28, 2003 | 08:36 PM
slowTA's Avatar
Car: '88 Formula
OK, I know it was a rookie question but a simple yes or no would work. Anyone?
Old May 29, 2003 | 09:37 PM
jwformula350ws6's Avatar
as long as your brake option codes r the same u shouldnt have a prob with switching
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ericjon262
Sep 11, 2015 06:07 PM
Z28camarokid
Sep 9, 2015 11:59 PM
