newbie with brake question
Old May 29, 2003 | 02:41 PM
T-Top T/A's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
Axle/Gears: 3.08
I have an 85 TA that came with a open, drum rear. I'm swapping in a 9 bolt posi disk rear out of a formula(87 I think) w/ 3.23 gears. my question is, do I need to change the master cylinder and/or proportioning valve also?? or will my stock setup be fine?
Old May 29, 2003 | 07:35 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Yes you will have to swap the master and combo valve, if you do a search on the topic you will find the right set to use.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
R3500
Aug 24, 2015 09:05 AM
redmaroz
Aug 16, 2015 11:40 PM
