another violent vibration at 110mph
Old Jun 1, 2003 | 08:40 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys, I used o have a horrible vibration at aroudn like 95mph and i traced it down to the idler arm, i replaced it and now the car is fine until like i'd say 105-110, it has a violent vibration like threw the whole car. I slashed a front tire on a curb on easter and i had to get new front tires so i know its not the balance cause they still do it. does anyone know of anything that i could check??oh yea, when i have the car up on jacks with the front wheels in the air i can move the wheel in the directions in turns a little, it got alot better when i did the idler but it still does it a little. should it do it at all or is something worn? thanks
Old Jun 1, 2003 | 10:36 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
If you have the steel driveshaft, it could it be the driveshaft is out of balance. And have to checked the tie rods and ball joints for wear?
Old Jun 3, 2003 | 03:15 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
yea its prob. the drive shaft go replace it with aluminum one
Old Jun 4, 2003 | 02:19 PM
82camaro's Avatar
Car: 82 camaro SC
If the steel shaft is still balanced it will be fine(no shake on my 82 from 0 to 5000rpm in OD). Since you say it's more through the 'whole' car, I would look at the rear stuff. In my experience, what you describe is usually a bad tire, out of balance tire, bent wheel, bent axle. A front end problem is usually felt much more in the steering wheel than the seat(whole car).
Old Jun 4, 2003 | 08:08 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
1)driveshaft
2)bad u-joints
3)tire/wheel out of balance
4)lower speed rated tires (note; tires with lower speed ratings can be fine at 80mph but may warp out of balance at over 100mph)
5) bad axle bearings/bad pinion bearing
6) bad road surface
7)wrong pinion angle
8)inferior dampen shocks
any one of these will cause vibration
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
