Stock LCA question
Old Jun 3, 2003 | 08:48 AM
no its a secret's Avatar
Stock LCA question
I have noticed alot of stock LCA's have 2 additional bolts attaching a metal plate inside the lower control arms. This looks as though it would stiffen them up a little bit. I am at a loss as to how it was decided which cars got them. I see some Trans Ams, Formulas and Z28's with and without them. I see alot of V6 cars with them. I'm thinking all non 2.73 cars got them. Anyone know?
Old Jun 4, 2003 | 11:00 AM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
If the ones you saw were off of the car they could be G-body LCAs. Hotchkis has them listed under the same part number as our cars too. The holes in the LCA are where the G-body rear swaybar bolts to, you need extra metal in there to keep the bolts from colapsing the LCA.
Old Jun 10, 2003 | 09:19 AM
Yes there is a piece of metal inside the LCA. 2 eyes with a short flat bar connecting them. I see these on F-Bodies (not all), all over the junkyards. I went ahead and grabbed a set and installed in mine. Can't hurt. I've driven it around a little with them. If feels a little more rigid out back. Or maybe it's just wishful thinking, lol.
Old Jun 10, 2003 | 09:43 AM
82camaro's Avatar
Car: 82 camaro SC
Yep, in a different car our rear LCA's could are used for the sway bar mount. Ever look at the LCA's in the front? In the middle they have a hole for a shock to drop through and 2 bolt holes to bolt up the shock--they also probably fit another GM product.
MustangBeater20
Oct 29, 2022 09:20 PM
TheExaminer
Aug 25, 2015 07:34 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
