loose component??
Old Jun 7, 2003 | 06:48 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
loose component??
when i drive i hear this rattle from the passenger side front axle, but its only heard when i come to bumps or dips in the road. I replaced the tie rods on that side, and recently had the shocks and struts done all the way around...what would make this sound? its only coming from the passenger side front. weird...but annoying and it makes the car really loose and a very uncomfortable ride especially for the passenger
Old Jun 7, 2003 | 09:54 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
come on someone help me out pleeeeeeeeeeeeeeze!
Old Jun 8, 2003 | 01:07 AM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
come on...
Old Jun 8, 2003 | 01:12 AM
lockdude's Avatar
It could be the control arms...My truck rattled like that until I had the upper control arm bearings replaced(big trucks use bearings, not bushings)
Old Jun 9, 2003 | 08:23 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Try looking at the little O-ring bushing on the brake caliper. This was my case too. If you take out the pins and look into those holes you will be able to see the O-ring. Use a small screwdriver to pry them out and get a new set of pins, I think they come with the O-rings. It might be called a caliper hardware kit depending on where you buy it from.
Old Jun 9, 2003 | 09:31 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
a loose caliper would make that side seem loose? its bumpy as hell, but its not as bad when i apply the brakes...might indeed be the case
Old Jun 10, 2003 | 05:23 AM
Formula_Fire's Avatar
Car: 1992 Firebird
Engine: TBI 305
Transmission: 4L60
I have the same problem with my 92 bird it also happens at low speed (or when I'm at a stop) when I turn the wheel, I'm working on it tomarrow but I pulled the tire off yesterday and noticed the sway bar bushings were really loose looking on that side.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Briandrex
Oct 5, 2015 06:20 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
