my lcas
Old Jun 14, 2003 | 08:22 PM
86IROCZ4u2nv's Avatar
Car: Black,,1986 IROC-Z
Engine: CARBED 305c.i.
Transmission: 5 speed, T-5
my lcas
Hey everyone, just a couple of stupid questions . I have a 1986 IROC and i took off my lcas when i went and rebuilt my rearend awhile back now i cant remember which way they go, do the bolt heads face out on both sides or do u see the nutside of the bolt when installed? also im dropping the car another 1.5" from the stock ROC specs am i going to need to worry about lca relocation brackets or anything like that whats your opinion thanks alot for your time Dan-
Old Jun 14, 2003 | 10:21 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
if the bolts fit, it doesn't matter which way you install them
if wheelhop increases, then you might want to think about relocation brackets... it's up to you really... it's really only a drag racing problem
Old Jun 14, 2003 | 10:55 PM
thanks that helps alot Dan-
Old Jun 15, 2003 | 12:31 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I think it may matter which direction the bolts go, but only for installation reasons.
On my convertible I have the crappy stock square tube SFC's under the door sills which give me about 1-2 inches b/t the frontmost bolt hole on the LCA and the SFC. The SFC has a hole in it that I have to back the bolt head through and then push it into the LCA bushing hole. SO, my bolts have to go in head first from outside to inside.
But the geometry of non-conv may be different in that regard.
Jorlain
Oct 8, 2015 01:57 AM
Americanmouse
Sep 7, 2015 12:10 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
NBrehm
Aug 5, 2015 07:57 PM
