Rag joint
Re: Rag joint
There are some that tried it that claim they work good, I have heard others say they get bind. I was one to get bind on the solid disc replacement. I am just posting what my personal experience was.
I guess the search feature on this site has been down awhile because I have in fact posted a review on this very subject on another post. If Unbalanced Engiuneering was searched it should come up- but again, I think the search engine has been down awhile.
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
Re: Rag joint
I guess I should have searched the whole entire forum instead of just the aftermarket product review and aftermarket vendor review sections. I didn't find yours, but found some other ones that mention binding, and someone even blamed the rag joint eliminator for tearing up their steering gearbox
I'm gonna forward Jason to this thread and the other one so that he can give us his $0.02 on it. I hope it all goes well with my car.
I'm gonna forward Jason to this thread and the other one so that he can give us his $0.02 on it. I hope it all goes well with my car. Joined: Nov 2002
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Rag joint
I'm bringing this one back from the dead because I want everyone to know that Unbalanced Engineering has a rag joint eliminator kit for 3rd gens, $41 shipped. All I have left undone for my steering is to rebuild my steering box. I'll let you know how it goes.
http://unbalancedengineering.com/Camaro/Rag_Joint_3rd
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: Rag joint
FWIW, I'm running an unbalanced engineering billet disk, with no issues at all.
That said, yes it could bind I guess, and I know and trust Dean, so I am sure he must have had issues with it. That said, mine works like a charm, and the added steering feel is a big plus.
Engine: TPI350
Re: Rag joint
I'm sure the other ideas work very well, but I think I primarily wanted the Unbalanced Engineering kit for the directions
Re: Rag joint
Thnaks for the reply John. I did not want to bash Jason's product. I know it has worked fine for many (hence why I posted what I did above about that fact- and you confirmed). Its just my personal experience was a problem. It could just be car specific meaning that tthe steering box mounts and the steering shaft mounts may line up better on some cars than others. I may have a bad aligned steering system or the box may be bolted on downward, etc... Who knows. You may want to try to loosen and retighten the steering column and the steering box after install if you do result in a bind feeling in the rotation at any point. I never tried this to be honest.
After replacing this rag joint with this solid disc, I noticed right away how terrible my factory steering box was and how the cushion of the original rag joint had taken the hard spot out of the box. I replaced the box, and noticed I still had a hard spot in the rotation- thats when I relized the dic was causing th ehard spot. The new box was needed though because I had lots of slop and then a hard spot (after box replacement I was left with no slop and still the hard spot. I then opted for the Flaming river setup and the hard spot was gone- I wrote it off as the solid disc being the culprit of a bind spot.
On a side note: THe AGR box I replaced my original one with is crap. THe valving is a tad low and you have to exert a bit more force/effort to turn the car. After having it in there now for about 3-4 months, I have already developed a small bit of slop again. It was firm at first with absolutely no slop, now its a tad esier to turn but has developed a tad of slop already- I recommend staying away from AGR This was a topoof the line box I bought through Summit Racing. I am going with a Lee box next and then ship this AGR to Lee for inspection and rebuild for my truck.
http://www.cardomain.com/member_page...2_138_full.jpg
ANd a pic of the Flaming River parts I paid about $260 for and are already rusting. I will pull them out and paint them. Disappointing, you would think they would make things out of stainless steel for that price. Looked nice when it went in.
http://www.cardomain.com/member_page...2_150_full.jpg
Engine: TPI350
Re: Rag joint
that flaming river setup looks really nice except for the rust... they should powdercoat those things considering their proximity to the headers.
sjorgens
Oct 1, 2015 07:54 PM
bubbaz28
Sep 18, 2015 02:09 PM
