wheels click when driving
Old Jun 25, 2003 | 02:55 PM
91blackgta's Avatar
I have 16" eagle alloy rims on my car. I drive down the road and anytime I turn the wheel the front wheels make a clicking sound and then it stops making the sound when I turn the wheels straight. Has anyone else have this happen? Anyway to solve it?
Old Jun 26, 2003 | 08:01 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
Maybe you tried this already if not ,, jack the front up,,( both wheels) Turn the tires one way and rotate them as fast as you can and see/hear for anything rubbing, If you see nothing you need to remove your wheels and see if something in the brake caliper is loose... Good luck...
Old Jun 26, 2003 | 12:24 PM
sllt1776's Avatar
Car: 89 Iroc-Z
maybe be alittle more detailed about when. are you using the brakes? High pitched or low popping sound? forward and reverse? speed? it could be so many different things.
Old Jun 29, 2003 | 01:38 AM
TwinTurboROC's Avatar
maybe steering box chassis mounting point
Old Jul 3, 2003 | 11:59 AM
Ezey Go's Avatar
Check your wheel bearings and ball joints. Both of these will do exactly what you described if they are bad.
Vintageracer
Jan 10, 2020 05:33 PM
B_Dubya
Aug 26, 2015 05:09 PM
justin57
Aug 20, 2015 07:05 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
