lowering a 2.8 plz help
Old Jun 26, 2003 | 08:34 AM
junkie's Avatar
Car: 84 camaro berlinetta
hi all my camaro has like a 6 in gap bettween my tire and top of the wheel well in the rear it looks retarded ..when my camaro is parked beside my buddys camaro mine looks like a truck i swear he probably could park his rear end under mine..well anyways ive been looking for lowering springs but they are all like 1in-2in drop.i need somthing a heck of alot more than that ...ill post some pics when i get my camera ..any suggestions????
Old Jun 26, 2003 | 02:00 PM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
I'll go with the Eicbach Pro,, although they say 1-2 inch this should be enough. I got a v8 and I feel it dropped it a little too much. You must understand that the E-Pro springs are way shorter than your stock. You don't want to go to low because your may encounter other problems ,, like bottoming out, wheels on the wells and so on... If you check thru out the site you will notice that the Pros are the way to go and many are happy with it.. I don't think it will be that much a difference because of your V6..... Check mine out after lower
Old Jun 26, 2003 | 02:36 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's no reason your stock springs would be doing that. Has it always been that way? Someone might've installed high-lift rear springs from another vehicle under your car. You might also have something bent under there. Are the spring perches on the axle bent? Are the springs seated correctly in the upper spring isolator (at top of spring between body and spring)? Are the spring perches facing the right way or were they flipped upside down for some reason? Try going to an alignment shop and asking them to take a look under there.
I have a 1986 Firebird, over 250,000 miles on it, and just rebuilt the whole front suspension. (250,000 miles of grease makes for a nasty job.) I used Suspension Techniques (by http://www.belltech.com ) v6 f-body lowering springs, part number 60115, from shox.com. The car sits pretty darn low now... I'm still getting used to it.
Here's a picture, before & after.
Old Jun 26, 2003 | 03:38 PM
junkie's Avatar
it always looked that high though i did buy new shocks and springs last year it made it sit even higher ill take it to shop to get it checked out thanks tomp
both of your cars look to have the drop id like tony90rs are those springs just for the v8 or do they make them for the 6 bangers too ????...i should have my camera this weekend ill post some pics soon
thanks
Old Jun 27, 2003 | 12:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, something's definately wrong back there. A body shop should even be able to check it out; they deal with suspension all the time from accidents.
And I should've mentioned in my message; the Suspension techniques springs are the ONLY ones made for 2.8/3.1 82-92 f-bodies.
Old Jul 5, 2003 | 10:18 AM
junkie's Avatar
heres a pic
Old Jul 7, 2003 | 01:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow!! Yeah, something's definately wrong, dude... better go to a shop and have 'em look it over. You had those springs installed? They might not've used the correct insulators for the tops of the springs, or installed the springs strangely... or used the wrong springs, etc... let us know what you find out! Hey what size tires are on the car? Are they super-small?
Zane Story
Oct 8, 2015 12:40 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
rjcme
Sep 5, 2015 01:23 PM
