Sway bar bushing torque?
Old Jun 26, 2003 | 09:56 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
i just put in some new Energy sway bar bushings and end link bushings. How tight should the end link bushings be tightened. I used a 9V Makita and just set them so they were tight with a slight compression on grommets.
Old Jun 26, 2003 | 10:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is a kind of shoulder on the end link bolt, that the nut will tighten down to and stop. Should take around 25 ft-lbs or so once you reach the stop. The bushings will usually distort (squish) quite visibly.
Old Jun 26, 2003 | 11:13 AM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Ok your refering to the spacer, so I just go ahead and tighten it up against that. I think I am real close now. Did not want to overtighten it last night I will double check tonight. Thanks!
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
J0386
Oct 12, 2015 07:46 AM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
