chorme or ploy ????
Old Jun 29, 2003 | 08:17 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
chorme or ploy ????
Hello all,
What is the difference between Chrome Moly Spherical and Polyurethane bushings?? I have a '89 bird with poly bushings installed. I am planing on putting on a wonder bar, torque bar and new sway bars, however the options ask to select between chrome and poly. (Chrome are more expensive, which I bet is better) Can somebody explain this to me.
Brad
Old Jun 29, 2003 | 09:18 AM
MdFormula350's Avatar
http://www.spohn.net/index.cfm?fusea...ct&productid=6
I took this straight from Spohn's website.
The high quality QA1 spherical rod ends provide for "bind-free" handling performance. The fluted polyurethane bushed ends are mounted onto the chassis (floor) mount to absorb road noise. These combo ended LCAs will still wipe out most bind, yet keep the noise increase minimal for a street driven car.
Old Jun 29, 2003 | 03:30 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
You are correct in assuming that the chrome moly rod ends are better then the poly. The rod end will allow the suspension to move and rotate bind free. However the ride will become stiffer and noisier. As the rods wear, you'll start to get a clunk clunk rattle sound. The poly will last alot longer, wont rattle, but will bind when cornering hard. The best compromise is the combo which uses a rod end on the axle side and a poly bushing on the frame side.
68 RS/SS Ragtop
Mid-Atlantic Region
Nov 10, 2014 05:52 AM
tpicamarokid85
Exterior Parts for Sale
Feb 3, 2011 09:34 PM
camarors29
Oct 17, 2010 01:56 PM
C.M.Jones
Carburetors
Sep 8, 2009 01:22 PM
Slow89Iroc-Z
Oct 19, 2002 11:03 AM
