shocks..
Old Jul 2, 2003 | 08:30 PM
Jeffbird's Avatar
shocks..
hey
just lowered my car with eibach sportlines.. and was wondering if i should get a adjustible shock?will these springs settle? its brought the car down quite a bit,(i dunno waht the sportlines are rated for? almost 2"??) but hair more would be nice, i can fit 2 fingers in the front and rear.. and will i need caster/camber plates?..i m just running OEM shocks at the moment...
Im very happy with these springs..would recommend them to anyone..changed the cars stance dramatically...rides WAY better than the cargo coil that i had in there(big block needs the heavy duty coil..no more BB though )
Old Jul 3, 2003 | 01:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Shocks/struts won't lower a car... they only dampen the spring to keep you from bouncing up and down like a basketball down the road. The adjustability only controls the firmness of the shock or strut... it lets you go from a firm ride to a soft luxury ride, with a few settings in between.
Old Jul 3, 2003 | 01:45 PM
graywolf624's Avatar
You should be fine without cc plates unless you plan on road racing(not to mention only like one company makes them that Im aware of and they cost a fortune. Their main purpose would be to increase your camber beyond that of the stock allowance, and if I am not mistaken the range is perfectly adequate even with a lowered suspension, just ensure you have an alignment done.). To reiterate what the man said, your shocks will not change your height. Shocks change your rebound/dampening/ect. Furthermore, lowering much more then 2" and you will get tire rubbing/ possible chasis damage. If you really want it, you can cut the springs. They should however settle a tad over the course of about a month after install.
Now Im off to contemplate how you knew what cc plates were but didnt know what shocks did. hmmm.
Old Jul 3, 2003 | 10:25 PM
Supercharged84Z's Avatar
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
speaking of cc plates..the guy who had my car before me had an eibach pro-kit installed and he said the tires were wearing funny (surprise, surprise!) and i was wondering if i needed a camber correction kit to fix this, but with what you guys were saying, and assuming the previous owner didnt get an alignment after the kit was installed, all i have to do is get an alignment to fix the problem?
Old Jul 3, 2003 | 10:49 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I think(I'm not sure, so don't quote me) that if you only use the pro-kit or something with a slight drop, there is enoug adjustment in the alignment that you don't need a camber kit
Old Jul 4, 2003 | 11:50 AM
Possibly, if the alignment is the problem that will take care of it.
Other things can cause bad tire wear, but I would start there. CC plates wont really change your issue.
Some issues that cause bad tire wear that I have seen or experienced: alignment, bad motor mounts, poorly manufactured tires, ect.
NOTE: none of the kits meant for the street drop the car more then 2". The range of adjustability of the stock car is enough to overcome this difference for a a street alignment configuration. You wont need the camber caster plates unless you are going beyond that or are road racing.
Camaro86IrocZ
May 26, 2015 05:17 PM
87_TA
20
Nov 24, 2011 09:29 PM
dukie
Apr 12, 2011 05:57 AM
garyjr2889
Oct 9, 2008 07:14 PM
