sway bar endlinks
Old Jul 10, 2003 | 03:10 PM
SLOWTBI's Avatar
sway bar endlinks
i was wondering if all sway br endlinks for f-bodies are the sme length...well, in actuality, i guess i'm asking if i can install '90 IROC swar bars (front and rear) on my '89 RS with very much fabrication?? any info is greatly appreciated.
Old Jul 10, 2003 | 03:34 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
I put IROC swaybars on my 86. I used ES poly bushings and endlinks though. I don't see why you would need to fabricate anything, unless you didn't have a swaybar to begin with, and there is no bracket for the end link.
Old Jul 10, 2003 | 03:48 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
No changes at all, they're all the same with the exception of the 1LE bushings which are harder rubber. I also used the ES poly replacements.
Ed
Old Jul 10, 2003 | 05:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Direct bolt-in. You don't mention the sway bars' measurements, but if they are the 1LE/WS6 type (hollow 36 mm front and solid 24 mm rear), you might consider either Spohn's or Top-Down Solutions' greaseables. The alternative is GM's higher durometer bushing and poly endlinks (which I prefer since they seem to seat better in the a-arm).
JamesC
Old Jul 10, 2003 | 07:19 PM
CaysE's Avatar
FOR THE LAST TIME, SPOHN DOESN'T MAKE POLY BUSHINGS!!!!!#@$!(%*^&#! They sell Prothane bushings, you can get them anywhere.
Old Jul 10, 2003 | 08:31 PM
JamesC's Avatar
CaysE,
I believe Spohn does make/modify the greaseables as does Top-Down Solutions. If not, the point is moot. He does after all provide a valuable part for our cars. No where above, by the way, does anyone claim that Spohn makes poly bushings.
JamesC
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
