gear box question
Old Jul 11, 2003 | 10:09 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
gear box question
Ok most places have a different part number for a trans am and firebird. Will all third gen gear boxes fit on any thirdgen car, or is there different mounting holes, or shaft angle or anything, I am assuming that the T/A part number is the quickratio, and the firebird is the base box. I think I will compair the part numbers with the irock gear box.
Any info will help,
Old Jul 12, 2003 | 07:00 AM
ede's Avatar
ede
physically they're all the same, they'll bolt up. as you most likely know so will a S10 box and even a box off a 1st gen. i'm sure there is a lot more interchangeabilty as well. it'd be stupid and costly for gm to make a differant box and bolt pattern for every application.
Old Jul 16, 2003 | 05:42 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
ok, here's one I could use some help on. The t5 in my 83 Z28 broke the o.d and basically trashed the whole trans, one from an s-10 was installed (about an 88) I was not the owner when all of this took place. Any help with gear ratios?
junkcltr
Aug 2, 2019 11:12 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
