Brake light on after bleeding
Car: 89' IROCZ
Engine: 5.7 L98
I bleed all 4 wheels with a mityvac and after I pressed the brake pedel the dash brake light came on and stayed on. There are no visable leaks and on a test drive it seems that only the front brakes are working, also the emergency brake does not work. How do I reset it? My chiltons and haynes manuels say that it is not a servicable part.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
brake light like the rear outside brake lights?? or you have that one in the dash...
if its the outside one, the switch under the dash stuck on..
if its the dash one, its probly thinking theres a prob because it sees wierd line pressure when bleeding.....
