power rack and pinion with a tubular K
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
if i were to install a tubular K member in my car is there a way to take a 4th gen rack and pinion and fab it to the K member, and use my factory power steering pump and hook it up just like it would be in a 4th gen. do the spindles have to be changed or would it work? has anyone done this?
Car: 4
Engine: 6
Transmission: 5
People make K-members with the mount already there for the R&P; so I'd imagine it's been done a time or 2. IIRC when you order one from PA Racing you just tell them which steering system you want, both kinds are regular production items.
Car: 1999 Z28
so the 4th gen peice will fit right in? i was only aware of a manual aftermarket rack not a power one. id like to retain my power steering but have the simplicity and weight reduction of a rack and pinion setup
Terrell351
Jun 13, 2021 01:13 PM
lt1z350
Sep 29, 2015 01:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
