What broke/ Came loose???
Old Jul 14, 2003 | 12:00 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
At first on the passenger side front...it sounded like a rattle...like a chain.
go over speed bumps...sounded like a chain rattling.
I was going to get it checked, but now___
i was driving down the road and heard a smack under the passenger side gloor board (passenger felt something hit the floor board)
and now it grinds like the brake pad is bad on the passenger side.
and when i cut the wheel sharp (parking/reverse) it grinds/thwacks.
fun fun fun
:lala:
Old Jul 14, 2003 | 12:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Have you crawled under to take a look yet? Try shaking the exhaust pipe; make sure the intermediate pipe isn't getting hit by the driveshaft's u-joint (caused by loose/missing panhard rod bolt)- but i doubt that's it; your car would be wandering down the road on it's own, and pretty badly, too.
Old Jul 14, 2003 | 03:51 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
I've been dealing with something similar - grinding noise on left turns, a weird clunk while doing a three point turn, etc. When I had new tires put on, the mechanic only pointed out a bad idler arm. Maybe that's something to check? Be sure to tell me if you figure it out.
Old Jul 15, 2003 | 08:10 AM
gonna check her this weekend..ill let ya know
Old Jul 15, 2003 | 12:28 PM
(BR)G-Machine's Avatar
How is the turn side to side? Rough? Too hard than other cars?
I am thinking the strut mount bearing broke or something.
Old Jul 15, 2003 | 12:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Might be. My upper mount bearing on the passenger side wore out; it gave a "groan" noise when turning the wheel. When I changed them out, you couldn't tell there was ever a bearing in there! (oops)
Old Jul 15, 2003 | 01:04 PM
yea makes noises when i cut it to sharp and feels kinda unstable...not as precise
Old Jul 20, 2003 | 02:14 PM
MFaulkner's Avatar
Car: 90 Formula
Engine: 305 TBI
I read on another web site (I'll try to find it) that the thump under the passenger's floor board was probably caused by a broken transmission mount. Maybe something worth checking out.
Old Jul 20, 2003 | 10:19 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Re: What broke/ Came loose???
go check your sway bar links. that's what is broken and sounds like a chain rattling. i'd replace both with poly ones if i were you.
Old Jul 21, 2003 | 05:59 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Sway Bar end links broke and is hanging down and making the noise. Replace both, if that is the problem.
83 Crossfire TA
Jan 3, 2016 01:26 PM
92camaro350cci
Oct 14, 2015 09:29 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
reactor60
Sep 22, 2015 01:44 PM
