comp eng sfc
Old Jul 14, 2003 | 11:27 PM
thehagg
Guest
Posts: n/a
comp eng sfc
does anyone have pics of these installed? didn't come with any direction. please help
Old Jul 15, 2003 | 10:04 AM
likeistoleit's Avatar
Car: 87 Iroc
Transmission: Tremec Tko
Bolt the front up to the subframe and hold them up to the floor, scribe where the floor pan iterferes with the connector. Use a cutoff wheel to cut the floor pan, go a little a time so you dont remove more of the pan than you need to. This is a long process of removing the connector and cutting. Make sure the you dont make the cut too wide so that you can weld the floorpan to the connector where it passes through the floor. You will probably have to trim some length off of them at the rear and elongate the front bolt holes. Lots of test fitting but done right it works excellent.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
no green
Jan 9, 2016 09:22 PM
