Tranny mount Broke
Old Jul 16, 2003 | 07:23 PM
JOHN/88IROCZ's Avatar
Tranny mount Broke
I replaced my trans mount less than a year ago and now the damn thing has already broke again. What would cause this and what could I do to fix it? Thanks alot for help and advise!My car is all stock no mods.
Old Jul 16, 2003 | 07:27 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
what causes this is the torque arm attached to the tranny. everytime you accelerate, the torque arm pushes up on the tranny. one way to solve this is to get a spohn torque arm kit. mounts the torque arm to the crossmember. or can get an energy suspension tranny mount. but still the torque will push up on it. just take longer before it rips apart.
http://spohn.net/index.cfm?fuseactio...t&productid=12
Old Jul 16, 2003 | 11:45 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Oil leaks can also weaken the factory rubber mount. Mine tore and Ireplaced it with an Energy supension part. Ride quality is different, but only slightly and I am very sensitive. Energy Suspension mounts also have an interlocking metal setup so that if the poly does fail, the metal inside the poly will keep movement to a minimum.
Old Jul 17, 2003 | 08:51 AM
MdFormula350's Avatar
on my past thirdgens i always replaced with rubber ones, and everytime i still seemed to weaken them over time, so i finally went with a prothane one for my formula and it is really strong, plus since i went with a spohn ta i bought the tranny mount from him also.
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
