Anyone using PA racing tubular A-Arms on a daily driver?
Old Jul 21, 2003 | 07:00 PM
formul8!!'s Avatar
Car: 2004 GTO
I would like to switch to these over the heavy stockers. I do not use my car daily, but drive it alot over the summer. Since I drive around the Chicagoland area and our roads here are not the best, I need to know they can take the punishment.
Also, any idea how less the a-arms with spring perches weigh over the stock arms?
Thanks!
Old Jul 22, 2003 | 08:24 AM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
I don't have them. But I, too, am planning on getting them. I think that they would be as strong as the stock, bein tubular steel. That, and they have to be built to take the abuses of road racing, so..
Old Jul 22, 2003 | 09:14 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
PA doesn't build things for road racing- only for drag racing in mind.
Old Jul 22, 2003 | 12:28 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
oh... my bad. so, maybe they aren't so tough..
Old Jul 22, 2003 | 01:21 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
I run PA's mild steel A arms with spring perches on mine. I don't road race or auto-x, mostly just drag racing and daily driving so I can't say how they'll hold up in those applications. Otherwise they're fine on the street...I've had no problems with them so far.
IIRC, the shipping weight on the box they came in said 18 lbs total for both arms.
Old Jul 22, 2003 | 01:43 PM
Kandied91z's Avatar
i have the chromoly versions....i've only put roughly 1,500 miles on them so far but have no complaints other then i currently have too stiff of a spring for my coilovers.
i have hit some decent bumps wether it was unavoidable or at night with no problems. i think you have a better chance of bending a rim. however if your going to drive like an idiot all things will break.
unless your going coilover or just looking to blow money i wouldn't buy them. it sounds like you plan to put it through some abuse and they aren't meant for that.
Old Jul 22, 2003 | 03:30 PM
formul8!!'s Avatar
Car: 2004 GTO
I am just trying to shave weight any where I can on the car w/o gutting it. These seem like a logical choice.
If they are not meant for road racing, then I should just keep the stock ones. Seems like the PA is the only company that makes tubular A-arms for thirdgens.
I just may have to develop them for heavier duty use....
Old Jul 22, 2003 | 08:20 PM
Kandied91z's Avatar
doesn't sound like your car is a road race car. there are versions out there for our cars that are road race worthy and exceptionally lightweight but prices range from 1,000-1,500 just for the arms.
i drive mine in every situation but i'm sure to watch out for things that can cause damage like severe bumps. if your careful in that manner you will be fine.
Old Jul 22, 2003 | 08:36 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Can you give me a website?
Old Jul 23, 2003 | 01:54 AM
Kandied91z's Avatar
nope. most are custom fab shops that don't use websites. there are plenty out there if you look most running cars as well.
i can give you numbers to people in my own area, but certainly you should be able to find similar people near yourself if your into that style of racing.
Old Jul 23, 2003 | 10:50 PM
The Man's Avatar
PA
I have one of there k-members..I am finally installing it. One of the holes were off on the a-arm and i had to grind it alittle bigger to get the bolt through. I was wondering if you use the factory(GM) torque specs on the a-arms bolts? Right now I have them just alittle snug and there seems to be pretty hard to raise and lower the a-arm by hand. I figure they would be pretty free moving. Do I have something that is wrong/ I lost PA's # anybody have it or email address?
Old Jul 24, 2003 | 03:40 PM
Kandied91z's Avatar
i didn't have that problem thankfully. are you using the stock arms with the k member or the custom a arms as well? the arms shouldn't "flop" around, but they shouldn't be snug neither.
try www.paracing.net
good luck
Old Jul 25, 2003 | 02:47 PM
The Man's Avatar
k-member
I have there a-arms and coil over kit.
Old Jul 25, 2003 | 10:32 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: k-member
hey. i dont want the man to hold us back.....
tell us a lil more info? it a daily driver? how meny miles on it? you hit any major potholes at speed and they fine? they look strong enough??? ect...
Drone358
Dec 10, 2015 08:16 PM
my86bird
Oct 23, 2015 12:20 PM
Lanz06
Sep 14, 2015 07:16 PM
rsrookie
Sep 5, 2015 07:08 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
