Adjusting height of Idler Arm on 3rd gen?
Old Jul 26, 2003 | 02:42 PM
Damon's Avatar
I wanted to double-check some work I jsut did when installing an new idler arm on a 92 Camaro. There are elongated slots in the frame where the idler arm bolts on. Obviously, there is an adjustment to be done. I installed the arm at a height that made the centerlink PARALLELL with the frame, side-to-side. In other words, LEVEL side-to-side across the car, using the lower A-arm bolts as a reference point . This put the idler arm bolts near the top of their adjustement range in the frame holes (very slightly higher in the slots than the original factory-installed idler arm).
Is this the correct geometry to shoot for? I am going to have it aligned but I want this to be right before I do. I doubt an alignment shop is going to take the time to adjust the idler arm height when they do the aligment.
Old Jul 26, 2003 | 05:18 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Sounds about right to me, but I used an angle finder. I'm sure your method works fine too.
Old Jul 26, 2003 | 06:15 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
There's a flat spot machined onto the bottom of the center link at each end below the tie-rod bolt holes. Measure the drop from the center of the control arm bolt to the flat....get them the same on both sides and you're set.
Old Jul 27, 2003 | 12:05 PM
Damon's Avatar
Thanks, guys.
customblackbird
Aug 15, 2021 10:16 PM
Ghettobird52
Apr 21, 2020 08:44 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
g.l.mos
Aug 22, 2015 12:02 AM
