What should I noted after put the lowering spring on (1")
Old Jul 30, 2003 | 12:57 PM
joekickass's Avatar
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Hi,
I would like to low my car a little (1'), what should I noted after put the lowering spring???
Can I go 255/60/15 in the front??
Joe
Old Aug 1, 2003 | 07:03 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
I guess you mean "what should you Notice once you put lower springs on". Depending on who makes them you should feel the car handle better, less nose dive and better looking. This also depends on the shocks you have. As far and putting 255 tires up front I would not recommend it. Depending on the rims you have you will probably have the tire rub on turns. I have 245-45/17 on my car and I get a little rubbing on sharp turns. The max I would go in front is 245,,, rears you may go higher.. Good luck
Attached Thumbnails What should I noted after put the lowering spring on (1")-dcp_2134s.jpg
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
TA8487
Aug 11, 2015 09:02 PM
