help me out guys: 84 vs. 86 WS6 swaybars from junkyard
Old Jul 31, 2003 | 09:44 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
first off, thanks for looking at my post. next.... here is the story. i went up to the pick-a-part nearest to me and found what i believe is a ws6 84 t/a (had disc brake rear end). i said "what the hell, i'll pull the sway bars from it" (look at the body roll in my sig pic). i come back the next day, lo and behold...there is an 86 t/a with the magical code WS6 on the rpo sheet. so... now comes my question: is there a significant performance difference between these bars? is it worth going back and returning the ones i've pulled for the 86's? thanks again.
Old Jul 31, 2003 | 11:21 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The 86 WS6 bars should be larger. But to be sure, measure your 84 bars and see. 87 -up WS6 are 36mm and 24mm.
Old Aug 1, 2003 | 10:17 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How does it go...? Wasn't '84 the last year for a solid 32mm bar? I have a rear bar off of an '84 trans am (along with it's 3.73/posi/disc axle!) and it was a 23mm rear bar.
Old Aug 2, 2003 | 12:51 AM
GM kept upping the WS6 sway bars just about every year till 87 when they got the 36/24mm combo. I guess their engineers felt that was the best combo for the street.
25mm and smaller rear bars are avail so you can taylor the over/understeer characteristics to suit your individual needs without having to use a smaller front bar.
armybyrd
Sep 28, 2023 12:16 AM
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Damon
Sep 26, 2015 04:29 PM
