LS1 swap is it possible to use a 4th gen Tubular K Member for a direct bolt in?
Old Aug 7, 2003 | 01:59 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
if i were to swap in a LS1 could i use a 4th gen tubular k member that way i dont have to relocate the mounts on the 3rd gen cross member, plus i wanted to use the rack and pinion out of the donar care. if i cant use a 4th gen tubular K ill probably just get a 3rd gen one and modify it.
Old Aug 7, 2003 | 04:02 PM
SteveSpohn's Avatar
No, the k-member is completely different.
ThirdGen Resource has LS1 motor mounts that will bolt right to the 3rdgen K-Member (stock or tubular).
Steve
Old Aug 7, 2003 | 08:08 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
thanks steve
Old Aug 7, 2003 | 08:36 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
one more question.. i had planned to run a tubular K member anyway but then it occured to me that itd be a good idea if i did a ls1 swap cause u have to notch the stock k member for the ac compressor to clear i think. but just to make sure... the LS1 clears the thirdgen tubular k without a problem right, assumin that im using TGRs motor mounts and tranny cross member.
Old Aug 8, 2003 | 05:57 AM
SteveSpohn's Avatar
I can't say for sure because I haven't done it and don't of anyone who has. But from the pics I've seen, I would assume you are correct. If I was gonna do an LS1 swap, I'd use a tubular k-mmeber to make life easy.
Old Aug 8, 2003 | 10:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
it LOOKS like it might work... but i would try to take some measurements before you spend the money.
Old Aug 9, 2003 | 02:09 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
ill have to look into it further.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
