strut tower brace
Old Aug 8, 2003 | 10:11 AM
bluepastu's Avatar
Car: 87 vert
strut tower brace
Do they make a difference? I'm looking in to getting the hotchkis.
Let me know.
Old Aug 8, 2003 | 10:13 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
yes
Old Aug 8, 2003 | 10:15 AM
bluepastu's Avatar
Car: 87 vert
how much of a difference did/do you notice?
does it matter if you get the 3point or 2point?
Old Aug 8, 2003 | 10:19 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i have a 3 point.
it is hard to describe the diffrence, my car is much more predictable to drive at the edge.
either a 2 point or 3 point will work fine.
Old Aug 8, 2003 | 10:39 AM
bluepastu's Avatar
Car: 87 vert
have another question. is there other advantages to using the adjustable panhard & LCA? the only advantage that I know of is if i used the lowering kit(which i don't plan on - i'm having a hard enough time pushing the jack under there and wondering about clearence).
Let me know, thanks for the quick responses!
Old Aug 8, 2003 | 10:42 AM
Dewey316's Avatar
Car: 1990 Camaro RS
adjustable LCA's aren't need, the adjustable panhard is a good mod, that way you can makes sure your rear is centered. and of course aftermarket LCA's are MUCH better than factory.
Old Aug 8, 2003 | 10:45 AM
bluepastu's Avatar
Car: 87 vert
wouldn't the rear be centered with the aftermarket non-adjustable panhard?
Old Aug 8, 2003 | 12:56 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Would not the adj LCA's be benifical in setting the correct pinion angle (for max bite?), especially if you have lowered the car any at all?
Old Aug 8, 2003 | 01:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
not really, the very slight amount adjusting the control arms will have on the pinion angle is not worth it, get an adjustable torque are to adjust the pinion angle.
Old Aug 8, 2003 | 02:58 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
You will notice a handling improvement with the Hotchkis STB. I have used it for the last five years and with the addition of SFC's last year my IROC is tighter, rattle and squeak free now then when it was new (original owner). It was a good investment along with the rear LCA's & Panhard Bar (all bt Spohn). My opinion, on adjustable items and locating brackets is if you don't need them don't get them. Just one less thing that need adjustments or go wrong.
Picture of Hotchkis STB on TPI.
Old Aug 8, 2003 | 06:55 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
This is my cousins on a 383/carbed.
Conrad
Old Aug 8, 2003 | 07:32 PM
1gta2c's Avatar
Look at the edelbrock 3 point tower brace. Vary strong and it is a more stronger brace than the 2 point brace.
Old Aug 8, 2003 | 09:31 PM
25THRSS's Avatar
Why is there a Hotchkis sticker on that edelbrock stut tower brace?
Old Aug 9, 2003 | 01:23 PM
twobirds's Avatar
Car: 1987 GTA 350
You know, I never noticed that. I 'll have to ask him. I thought it was a Hotchkis STB. But sure enough, it is not.
Conrad
Old Aug 9, 2003 | 01:48 PM
drifter-x's Avatar
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
Does the Edelbrock brace fit around the tbi air box, too, or just the open element?
Old Aug 9, 2003 | 02:55 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am not sure if it fits around the stock air box. But if it doesn't who cares, go to autozone and get a 14x3 air cleaner assembly for a whopping 15 big ones and chock up another mod to the list.
Old Aug 9, 2003 | 05:16 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes the Edelbrock 3-point STB fits around a stock air filter housing.
Lon
Old Aug 9, 2003 | 06:16 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
hey an idea just cam to mind.LOL
has anybody put sheet metal on top of the 3 point braceso that just the air filter comes throught and not hot air from the manifold and the exhaust manifolds. and you could put refelective heat shield tape on the bottom so it refelects the heat that goes in through the open element because dont know about you but after driving for about 20 minutes my car isnt as peppy.
Old Aug 10, 2003 | 09:58 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If you did that you would restrict air flow to the air cleaner because the air cleaner sits flush with this type of strut tower brace. The best ways to combat heat is with a cowl hood, ceramic coatings, and a true cold air intake system.
Old Aug 15, 2003 | 06:57 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Hotchkis signiture series STB here, it made a nice improvement in steering and cornering.
Old Aug 24, 2003 | 03:54 PM
Tibey's Avatar
Car: 1987 Chevy Camaro Z28
Engine: 305, 4bbl, A/C, T-Tops
Transmission: 700R4 4speed Automatic
I bought one (Edelbrock for TBI/carb.) but in the rush to get it I didn't check that it wouldn't fit on cars with the A/C on the driver's side... does any one want to buy it? $120 takes it!
Old Aug 25, 2003 | 01:44 PM
bluepastu's Avatar
Car: 87 vert
do you have a pic of it? email me if so.
Old Aug 26, 2003 | 05:36 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i think it helped my car a bit. made the rear fell a bit looser though...well until i got aftermarket panhard and lca's. i think it is a good mod although sfc's are a better one.
Old Aug 26, 2003 | 06:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If I would have done ot over I would have gotten my subframes first. You can see in this picture how stiff the front end was and how well the car handled with the springs, rear supension stuff and big rubber. I actualy pushed the side of the car out a little. I think it is either twisted or just flat out bent. The passenger side is indented the same out that the driver side sticks out.
Old Feb 26, 2004 | 09:19 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
on the Hotchkis STB, are there any hood clearence problems?
Old Feb 26, 2004 | 11:20 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
I believe hood clearance is fine with all of them.
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
tcflint
Sep 27, 2015 05:58 PM
