88 trans am better than mine?
Old Feb 17, 2004 | 10:13 PM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
my friend is parting out his 88 trans am and i was wondering what suspension parts are better.
Old Feb 18, 2004 | 02:25 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
take a look at your RPO codes.... due to the fact that you're a base firebird, you will either have FE1, FE2, or F41 suspension..... I BELIEVE... FE1 having the smallest diameter sway bars and the cushiest ride, and F41 being more performance oriented...
also, check the RPO's of the t/a... most likely it'll either have F41 or WS6.... if it has either of those RPO's.... grab the sway bars and all the mounting stuff....
dont worry about the springs or the shocks/struts if they are factory ones.... they're probably shot.
i'm not sure about the panhard bar, torque arm, or lower control arms stock... they probably arent any better than the ones u have now.... but if any of these pieces are aftermarket pieces, then grab 'em!
Old Feb 18, 2004 | 06:53 PM
Car: 1992 Firebird
ok ill go check after i get off work.
Old Feb 19, 2004 | 03:02 PM
Car: 1992 Firebird
i have the FE1 rpo. so a 94 z/28 doest have better sway bars?
Old Feb 20, 2004 | 02:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
'94 Z28?
Old Feb 20, 2004 | 05:11 PM
Car: 1992 Firebird
i posted a topic before this one and asked about a 94 z/28 suspension and they said that every thing in the rear was the same and the front was diff. then i asked about the 88 t/a.
Old Feb 20, 2004 | 07:16 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
if you have a reg ol firebird then the 88 ta suspension is better. now the 4th gens whole front end is different. they use a coil over strut assembly and a different steering rack. they supposedly handle better, but with coil overs you feel more of the road.
Old Feb 25, 2004 | 08:08 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
:nono: FE1 or F41 only on the base Firebird.
FE2 was top suspension for the Camaros I think....
Old Feb 25, 2004 | 09:24 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
yeah....wasnt sure.... thats why i threw an "i believe" in there....
Old Feb 25, 2004 | 09:40 PM
Agent13's Avatar
Engine: LG4
Old Feb 26, 2004 | 06:51 PM
Mr. TurboTA's Avatar
Guys!
Just measure for 36mm front bars, and 24mm rear bars!
Then, get a wonderbar, and rebolt it all up with polyurthane!
Get some GTA style wheels with 245-50ZR-16 tires.
You will not believe how well your car will handle! Right, Alex?
Hope this works,
George
Old Feb 26, 2004 | 11:56 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Well, he already has gta wheels, so thats one step closer...
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
