disc prop valve for drum brakes-WOW waht a difference!!
Old Aug 10, 2003 | 08:32 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Alright, car started out as a drum rear, got a disc rear and also installed the disc prop valve as well, but read alot of posts saying it was'nt necessary. Anyway, blew that rear end and got a new one with drum brakes, but since it's mostly a 1/4 beater I did'nt put swapping the prop valve back to drum type high on the list until I got to experiment with it. Holy cow, this car has never had brakes, and I mean NEVER had brakes like it does now. First time I tried them I about went through the windsheild it was that dramatic. Now when I hammer the binders the whole car squats down and stops ASAP, which might be a possible down fall for a daily driver. I'm not sure the actual pressure difference between the 2, but I assume since the whole car squats instead of nose dives that the rear drums are getting a little more pressure than before and could casue a problem in the winter. But for me, this set-up is killer, seems weird to feel your seat fall from under your butt when you mash the brakes.
Old Aug 11, 2003 | 06:00 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
good to know.. I'm still running the disc brakes with the drum valve... I don't even think I can lock em up... I don't have an e-brake yet either, cause I didn't get the cables with my new rear... maybe I should at least get one of those things, huh?
you could also spend about $40 and get an adjustable valve for summer/winter adjustments if you like the braking power on dry roads... not sure how well those things work, or if they work the way I'm thinking... just an idea.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
