Drum Brake problem
Old Aug 18, 2003 | 12:53 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Drum Brake problem
I was trying to remove the back plate on my 83 when I twisted off one of the 2 small bolts that hold the back plate to the axle. I can't get a drill to it from the back or front of the plate because of clearance in order to use a backout. Any suggestions would be great.
Would the backplate be secure enough with just one of the small bolts and the large top bolt??
thanks,
phil
Old Aug 20, 2003 | 12:13 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i am not sure what you mean by "backplate" i have done i drum brakejob once about 4 months ago, but i don't know what stuff is called. if you can remove the item the bakplate goes into (sounds like that would be attached to alot) then pull it use a backout and go from there. if not... ummm time to just by a whole new car jk
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
