If I could see some SFC installed.........
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I recently started to sand down my Z because, well the factory paint flake look isnt cutting it. Anyway, I found a crack in the roof and though it needed some SFC to stiffen up the body. I did the usaul research on the subject and realized since I'm a fabricator, why not build them? Long story short, If I could see some pics installed, I would be able to whip them out at lunch. I'm more concerned where they need to be attached, and where to weld. I'm calling on those wise men before me, to show me. Thanks
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
the roof crack is normal jsut about every thirdgen will get that from normal driving. SFCs are a good idea anyway, i wish i could make some.
Engine: Blown 383
I did do a search, but the one's I found were very scary to lool at. The few I saw looked like someone squeezed chicken poop all over them. That is why I asked for an expert to post some pics. Thank you.
Engine: Blown 383
Thanks for the input guys, but I think I figured it out. I finally got off my *** and jacked up the car and looked at the situation. I have a plan of attack, that I think will work out just fine. And will only cost about 15 bucks.
chris
Engine: Blown 383
I'll post, but I wont do it till next spring probaly. The car is down for repairs and dont plan on installing them till then.
MyBluz:- I know you are pretty much sorted, but here's a few threads that someone in a similar situation may benefit from reading. Hope the project goes well!
SFC's Where do these "tie in" up front (Inc. pics)
https://www.thirdgen.org/techbb2/sho...sub+frame+pics
15$ subframe connectors (Purely coincidental I'm sure!).
https://www.thirdgen.org/techbb2/sho...installed+pics
Spohn SFC Installation Questions... (Inc. pics)
https://www.thirdgen.org/techbb2/sho...hreadid=183509
Bright Red Spohn SFCs (Inc. pics)
https://www.thirdgen.org/techbb2/sho...ght=spohn+pics
http://www.spohn.net//index.cfm?acti...d&contentid=10
Pics of the Spohn SFC's installed.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Strangely saleen(yes mustang)used to sell these.Under the name "aero camaro" .
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Those are Spohn's old boxed type SFCs. His new tubular ones follow the same pattern but are only tubular.
Ed
Ed
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
luvofjah
Sep 26, 2015 08:28 PM
