What torque arm to use with LT headers...
Old Aug 26, 2003 | 12:58 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
I have just finished getting my 91 T/A on the road, and it has LT hooker super comps, and the mufflex y-pipe.
also, what should i do for a DS loop? i'm thinking about making my own seriously...
anyways, what torque arm shoudl i use? and are there any that will change the torque arm connection to the crossmember?
Old Aug 26, 2003 | 04:34 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: What torque arm to use with LT headers...
https://www.thirdgen.org/techbb2/sho...hreadid=197804
Old Aug 26, 2003 | 06:40 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
The spohn torque arm won't clear hooker longtubes and mufflex y pipe.
Old Aug 26, 2003 | 09:59 PM
SteveSpohn's Avatar
I don't think any crossmember mounted torque arm will, your only choice is a transmission mounted torque arm. Which, by the way, we are currently designing one
Steve
Old Aug 27, 2003 | 01:13 AM
OMINOUS_87's Avatar
Look into the BMR trak pak. It mounts to its own crossmember that needs to be welded into your SFCs, it might clear.
Old Aug 27, 2003 | 12:29 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I am in the same boat so to speak. I am running true duals and am needing a driveshaft loop first, and will eventually get a tourqe arm.
Old Aug 27, 2003 | 03:15 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Do yourself a favor and get a Random Tech adj. torque arm and have a DS loop custom fabbed at your local exhaust shop. Then powder coat the loop and bolt it back on.
Thats what I'm doing. I have Hooker longtubes, a six-speed, and custom mufflex y-pipe with SPD conversion X-member and it's a pain to find a DS loop that works with all of that. Just my $.02
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
