Spohn torque arm users
Old Aug 23, 2003 | 11:32 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I was looking at Spohn's adjustable torque arm @ their site and I am confused a little. I do not understand how it bolts up on the tranny end of it. It looks like it some how takes place of the trans. mount/crossmember? Or maybe someone has a better picture to look at.:hail:
Old Aug 23, 2003 | 11:54 AM
SteveSpohn's Avatar
It comes with a trans crossmember, you remove your stock crossmember and install ours. The torque arm connects to our crossmember.
Steve
Old Aug 23, 2003 | 03:03 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Which is a VERY good design because it takes all that stress off the tranny tailhousing and puts it directly on the crossmember instead. This makes the torque arm more effective as well as saving your tranny mount from grenading every few months.
Old Aug 23, 2003 | 07:59 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Two diff Spohn cross members but that should give you a better look at the mounting point.
HTH
-Schultzy
Old Aug 23, 2003 | 08:35 PM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
realy good ouestion an realy good answer. We learn alot on these board. So no problem clearing the speed sensor?
Old Aug 24, 2003 | 12:40 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
oh thats sweet:hail:
Old Aug 24, 2003 | 01:36 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
They clear the Speedo connections fine
Spohn sells top notch products- Note: Tq arm, Subframe connectors, Swaybars, Adj LCA's. Great products- Things are just a bitch to keep clean when its a daily driver.
Old Aug 24, 2003 | 09:38 PM
MdFormula350's Avatar
its a great suspension upgrade.
Old Aug 25, 2003 | 03:37 AM
bubbareno's Avatar
Transmission: t-5
Wil that crosmember work if we were to do a t-56 swap?
Old Aug 25, 2003 | 05:28 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
They have a crossmember for T56-swap cars, IIRC.
Old Aug 25, 2003 | 11:32 AM
SteveSpohn's Avatar
Yes, you can see a list of what we have the kits for by clicking here:
http://www.spohn.net/category.cfm?categoryid=1047
We'll soon be adding to the list:
LS1 with LS1 T-56
LS1 with LS1 4L60E
Richmond 6 speed
4L80E
Steve
Old Aug 25, 2003 | 06:25 PM
MYBLUZ's Avatar
Engine: Blown 383
Thanks for the pics guys, much better! I see, and I like. :yourock:
Old Aug 25, 2003 | 06:50 PM
bubbareno's Avatar
Transmission: t-5
what i ment to ask was if I was to put it on my t-5 could i use it latter on down the road? If i was to do the swap. Also Im wondering how it bennifits handling.
Old Aug 25, 2003 | 08:36 PM
SteveSpohn's Avatar
The torque arm itself is the same, but if you switched from a T-5 to a T-56 you'd have to get the T-56 crossmember. The crossmember for the T-5 would not work with the T-56.
Steve
Old Aug 25, 2003 | 09:48 PM
LilJayV10's Avatar
Engine: 406 Roller
Anyone running dual exhaust with this setup?
Old Aug 26, 2003 | 12:50 AM
Wolfpack's Avatar
Car: 86 Iroc
Planning on getting the Torque Arm myself in the Future but was wondering about something. If I got one now with my Original 10 Bolt Rear and upgraded to a 12 Bolt Rear would I need to get another Torque Arm?
Old Aug 26, 2003 | 11:34 AM
SteveSpohn's Avatar
No, it will work on stock, 12 bolt, or 9" rears
Steve
Old Aug 26, 2003 | 01:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Dana 44's too.
Old Aug 29, 2003 | 08:26 PM
twiztid dreams's Avatar
Car: 84 Firebird
Engine: 2.8l
i would also like to know. ne1 runnin the maniac motors true dual exaust with the torque arms?????
Old Aug 29, 2003 | 10:55 PM
87350IROC's Avatar
Car: 87' IROC
Steve, you're pretty much "the man" :hail:
Old Aug 30, 2003 | 12:39 AM
EvilCartman's Avatar
Car: '82 Z28
I guess a couple more dirty pics couldn't hurt hehe
morrow
Jan 13, 2024 12:29 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
