Strange Rear end noise
Old Aug 27, 2003 | 10:09 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I am not even sure what kind of noise it is. The car has been making a kind of dragging sound when i am on the brakes almost stopped.
It drags, but when i stop the noise continues? Also, i have been hearing a popping noise from the rear. I jacked up the right rear, took of the wheel(could not get the drum off) when i grabbed the drum to pull it off, it made a pop noise and the whole assembly move towards me like a 1/16 of an inch(that is an educated guess, but enough for me to rock it back and forth)
Like i said, i can't get the drum off, and it almost looks like the drum is not on right. Instead of the studs being straight through the holes, the threads are resting against the drum way too tight.
Any ideas what could be wrong, and how should i get that drum off? I tried to knock it loose, no dice there.
Old Aug 28, 2003 | 08:06 AM
9D1BURD's Avatar
Car: 1997 Z28
TTT
Old Sep 2, 2003 | 09:04 PM
joshp14's Avatar
The pads may have grooved themselves into the drum. You have to loosen the self-adjuster in order to let the shoes ease up on the drum so you can pull it off. Another thing you may want to try is smack the drum with a rubber mallet...sometimes this loosens them up. DO NOT use a metal hammer.
Old Sep 3, 2003 | 03:54 PM
Eternal's Avatar
the axle being able to move in and out is normal. you can also use a pull hammer on the outside of the drum instead of a hammer.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
