Is it springtime?
Old Sep 3, 2003 | 02:04 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Help!!Is it springtime?
I need to replace springs, and the thing already rides too low. I found Moog replacements for the factory (not lowered). I have one concern. (a little knowledge is a dangerous thing) RPO codes 6DB, 7DB, 8NN, 9NN, say Spring, computer selected, rear, right hand(or left hand, or front) Are the springs different? WTF does this mean?
Old Sep 4, 2003 | 12:17 AM
bigals87z28's Avatar
Car: Check The Sig
might be a combo of your springs and struts/shocks that is making your car sit so low. Im not 100% on what all that means, but from what i understand, depending on the engine you got different springs.
Old Sep 4, 2003 | 06:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The factory picks springs for each corner that match the car's exact weight on that corner.
Of course, they use such crappy springs, within 10,000 miles they're used up. Factory shocks are even worse.
Go ahead and use the Moog replacements. You won't believe the improvement. The correct part # is 5662 IIRC. For the rear you want the CC635. Make sure you put in new shocks and struts, and new front control arm bushings, while they have all that stuff apart anyway.
Old Sep 4, 2003 | 09:02 AM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
Shocks are fairly new(less than 5,000 miles), and all bushing have been changed to poly. The rear springs are the problem. The rear sits about 1" lower than the front. Bad case of old age (happens to us all) Thanks for the info. Oh, by the way, these springs have 150,000 miles on them. They're gone.
Old Sep 4, 2003 | 09:18 AM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
I assume the set offered by Steve Spohn is the right one, although he says the number is Moog-001. Any thoughts?
General Custom
European Region
Jul 17, 2016 07:32 AM
Anti_Rice_Guy
Apr 23, 2015 08:31 AM
TennesseeIroc-Z
Feb 10, 2014 09:55 AM
Synapsis
South West Region
28
Apr 19, 2004 01:03 AM
