anybody running koni's?
Old Sep 10, 2003 | 01:31 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
does anybody out there have koni's red or yellows?
i heard the yellows have a stiffer ride, i was wondering if anybody knows from experience? I'm not sure what level of ride quality to expect. I want something tighter than my 13 year old shocks and struts, but this also is a daily driver, so i would like a little comfort.
thanks
Old Sep 10, 2003 | 03:08 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I have Sport Yellows with a Prokit - if the road conditions were perfect it would be OK for a daily driver but the reality is that most roads are badly maintained and with my set-up I feel very bump and pothole - I only drive it weekends and I spend a lot of time trying to avoid things on bad roads - depends where you live but for most people yellows are probably a bit much for everyday use.
Old Sep 10, 2003 | 05:54 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
How important is it to get adjustable shocks/struts if you are going to lower your car?
All of a sudden your car is 1-2"s lower, reduces the travel length on the shock/strut, also puts it in a different travel location....
Old Sep 10, 2003 | 07:19 PM
colonboy14's Avatar
Car: Trans Am
I have Koni Yellows, and I think they are great. You will no doubt have a stiff ride, but I don't mind at all. The car just feels connected to the road. I also have stiffer springs and drop spindles, so I don't know what just the Koni's would give you, but If you don't mind a very stiff ride, go with it.
Old Sep 10, 2003 | 07:41 PM
mgilorma's Avatar
Car: 90 RS
thanks for the replies, how much ajustability do you get with those yellows?
any reds out there?
Old Sep 10, 2003 | 08:54 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
i hate to bring other cars into this thread, but has anyone ever drivin in a 2003 nissan maxima? the ride feels really nice...i dont know what a 3rd gen feels like with upgraded suspension (sfc's, stb's, koni's etc..) but can anyone compare the two? or maybe compare a upgraded 3rd gens suspension to another stock car that feels the same as the third gen with upraged suspension? thanks
Old Sep 11, 2003 | 08:25 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Koni says to use the softest setting when you install them. As far as I know the adjustable feature is mainly to compensate as the shock wears - (seen that on a couple of posts on here) - although obviously you can use it to stiffen everything up.
When I installed mine I set the rears on softest and I found that I needed a half turn on the fronts to get it the way I wanted it.
I really like the way that car handles but there's places where I don't like to take it because the roads are crap and it beats the snot out of the car.
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
perZ
Aug 21, 2015 05:51 PM
