View Poll Results: which ones should I get?
billstien HD
35.29%
koni reds
23.53%
koni yellows
11.76%
tokico illumina 5-way
29.41%
Voters: 17. You may not vote on this poll
please vote: shocks
Old Sep 11, 2003 | 09:58 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
please vote: shocks
this goes along with my other posts, because I'm not sure which ones I want to go with. I spent 2 hours reading on here last night, and now I am probably less sure than i was yesterday. So I'll leave it up to the audience.
Old Sep 11, 2003 | 10:04 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you can't beat koni.
the extra weight savings from you wallet helps too
Old Sep 11, 2003 | 11:25 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I would go with Billstien
Old Sep 11, 2003 | 02:35 PM
laiky's Avatar
just installed Illuminas to replace my failing Tokico HP's. Night and day difference! i love the illuminas. Its also fun trying the different settings although ride quality seems good even on the stiffest setting. FTI #1 the softest setting is considerable better than the HP's when new.
Old Sep 11, 2003 | 06:59 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
The main reason that I bought the Illuminas is because the rears can be adjusted by crawling into the back seat. With the Konis you have to get the rear shocks at full extension, then rotate the tops (inside the car) while a button is pushed on the body of the shock (under the car.)
I will say that the adjusters on the Tokicos leave just a little bit to be desired, but still a well made part. I've also heard that they have a really good warantee program, haven't tried it for myself.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
