LCA relocation brackets?
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Do you have to use LCA relocation brackets with adjustable LCAs? I got a smoking deal on some Spohn tubular CrMo poly/poly non-adjustables a couple weeks ago and now I've got a line on someone with BMR bolt-on relocation brackets for almost half price.
I just need to know if I can use the relocation brackets with stock length arms. I hope so, but if not, I might be selling the non-adj Spohns to finance some adj Spohns
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
yes the holes are set in an arc,so they work with stock lenght arms in any position, as long as the brackets are installed correctly, there was a person on here a few weeks ago, who didn't install them correctly, and had problems with stock arms.
Originally posted by RB83L69
Don't believe the "bolt-in" thing. Bolt them in, then go get them welded. They will not remain stable with only the bolt holding them.
Thanks for the info, guys
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Have a lot of people had wild success with LCAs and relocators? I saw zero traction gain after I installed them.
If I could do it over again, Id have gotton the torque arm first.
If I could do it over again, Id have gotton the torque arm first. nape, like was mentioned, as long as the reloaction brackets are put in correctly, the solid LCAs will go in fine. But you know, you should go adjustable anyway, cause I know someone that would like some solids at a good price.
