anyone know what this is?
Old Sep 15, 2003 | 07:24 AM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
When Im driving my car at slow speed and I hit a small bump, I get a noise from the rear of the car. It sound to me like keys rattling, its not real loud but I notice it. I have no idea what it could be.
The car is completely stock, 146k miles.
Rich
Old Sep 15, 2003 | 07:43 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
check your sway bar end links.
Old Sep 15, 2003 | 08:10 AM
88TAJeff's Avatar
Car: 88 T/A
Also check your track bar brace where it bolts to the frame. I had all 3 of the bolts fall out and it was just hanging there banging around.
Old Sep 15, 2003 | 09:28 AM
MdFormula350's Avatar
check behind the rear trunk interiors pieces, also in the little compartment that opens with a key. could be loose nuts and bolts just sitting in their.
Old Sep 15, 2003 | 09:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it sounds like coins jingling in your pocket, it's probably the sway bar end links. Very very common.
Old Sep 15, 2003 | 08:18 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
Sorry I have been gone all day doing my CAI. It does sound like the change in my pockets, I will check all these items.
Old Sep 20, 2003 | 12:37 AM
apinaire's Avatar
Car: 84 berlinetta
Engine: 383
Transmission: 700-R4
i f you have rear disc brakes it could be them. mine do the same thing and i have found out that it dosnt cause any problems besides noise. i forgot exactly what the problem is, but it wont harm anything.
Old Sep 24, 2003 | 12:27 AM
tyson__91's Avatar
Car: 91Z 99Z 68 SS
I used to have an 88 Iroc that would do the same thing. Im guessing you have disc brakes. What it is when you do not have brakes applied your brake pads in back are loose ( check with your finger when car is parked) causeing them to jiggle around. Im not sure how to fix it but i guarentee you your brakes in the rear dont work, jack up the rear of you car put it in drive and hold the brake as hard as you can i bet your cant make the wheel stop moving. The only way i know to fix this is get new calipers and pads, possibly only new pads might fix it. Or get some of a 1Le car 91-92 Let us know what you find out.
Old Sep 24, 2003 | 06:07 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
Since I am getting married this Sat. I have all week off. I will check all these possibilities today.
Your help is appreciated.
Old Sep 24, 2003 | 09:29 AM
Adam Jones's Avatar
I had the SAME NOISE. Got those swaybar endlinks replaced and the noise is gone. Car handles loads better too.
Thanks RB8.
-AJ
Old Sep 24, 2003 | 04:37 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I've had rear end noise from missing sway bar end-link bushigns that rotted out. I've had noise from loose LCA bolts (most annoying rattle). And also from the top shock mounts behind the rear seat. And, to be completely safe, pull off your center-cap cover to make sure you did not shave a stud bolt or have a loose lug-nut (had that happen too).
-Matt
Old Sep 29, 2003 | 09:27 PM
SgtSkip's Avatar
I love it, get married and work on the car for a honeymoon! Best wishes and good luck!
Old Oct 11, 2003 | 08:50 PM
SweetS10v8's Avatar
Engine: L98 & 355ci
Well its been CRAZY. I got married and moved to OH. Havent had any time to do anything to the car but change the oil, I actually almost gave in and took it to Vavoline, SHHH dont tell her.
I dont have any access to the internet, not even 56k yet. Its devistating to someone who was online 3hrs a day after work, I used to think I would die if i ever went back to 56k from my cable modem, now I am dreaming of 56k..lol
Started school and am learning everything about A/C right now. its great, I will check all of the above when I get into my suspension class.
Old Oct 11, 2003 | 11:15 PM
CaysE's Avatar
It's probably the end-links. Two of mine were broken, causing lots of noise and one hell of a swaying car around turns. Wheee!!
Anyway, I replaced all four with Prothanes, and the noise is gone and I don't feel like I'm about to tip the car over when turning.
