putting early disc's on an early drum rear???
Old Sep 17, 2003 | 06:49 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
car is an 86 z28, originally had a 10 bolt drum rear. i swapped that for a 9 bolt with discs. Well i blew the 9 bolt up a couple weeks ago so i'm trying to put the 10 bolt back in. I had planned to simply swap the 10 bolt to disc, that way i didn't have to change the lines, and prop. valve and all that again... seems easy enough....
so heres my dilemna, i got to put the disc brake backing plates from the 9 bolt on the 10 bolt, and they arent even close to fitting on the flange. I can see that the top of the flange will have to be cut, which is no big deal. The big problem i'm having is that the existing bottom 2 holes on the flange don't match up to the backing plate, and the flange doesn't appear big enough to drill new holes where they need to be.
has anyone done this swap? what do i need to do to make this work?
Eric
Old Sep 17, 2003 | 08:40 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Mine not be an option your looking for and quite the unscientific approach but, I just welded mine to the flanges...
Attached Thumbnails putting early disc's on an early drum rear???-discbrakes.jpg
Old Sep 17, 2003 | 09:30 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
man why the hell didn't i think of that. that looks like it works perfectly.
I just wonder if my welder is up to that task. what type of metal are those backing plates?
Eric
Old Sep 17, 2003 | 09:58 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
probably just mild steel
hectre13
Dec 11, 2023 08:14 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
novaderrik
Aug 10, 2015 12:44 PM
3rdgenparts
Aug 6, 2015 09:03 AM
