Brakes
Old Sep 18, 2003 | 01:53 AM
curtybird's Avatar
Brakes
aight well my brake problem is this. when i push hard the pedal feels kinda "mushy", the brake light comes on(only when i push hard) and she pulls to the right. i got new rotors calipers and pads on it so i dont know. suggestions please
Old Sep 20, 2003 | 01:50 AM
1a12's Avatar
check the vac. booster. That could be failing. Might explain the the having to push the pedal hard. The mushy feeling could be air trapped in the lines. Just some places to start.
Good luck
Old Sep 20, 2003 | 07:26 AM
mikes92rs305's Avatar
did you bleed the brakes when you changed the calipers? if you didnt, start from the farthest point (Pass. Rear caliper) first, then work your way closer to the master cylinder. also, check for a collapsed brakes hose...your better off changing them anyway. the rubber cracks and leaks from the heat and old age. let us know how it goes.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
