koni special d shocks
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
I just bought these nib on ebay guy said they were adj road shocks when I asked. these are drag shock aren't they? will they be streetable? what kind of ride can i expect?
Koni Spec D's are adjustable. Mine have a decal on the side showing how to adjust them. Very easy to do. Pull down the dust boot and you'll see a button, hold it down, then turn the shaft clockwise to 1 of 3 firmness settings.
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
yes I see how to adjust, but are they drag shox or road shox there does not seem to be any change in compresion when I adjust just rebound.
Engine: 305 TPI (LB9)
Transmission: WC T-5
and that's exactly the problem I had with mine... no significant difference when you adjust them. I wanted a stiffer, more easily adjustable shock so I went with the KYB AGX's. As a gas/hydraulic- The 'Special D' is more of a performance shock with a softer ride. I've never heard of anyone using these for drag racing.
When you adjust them, I believe you have to bottom out the piston, push the button, then turn the shaft.
Car: 1989
Engine: 5.7
Transmission: auto
Axle/Gears: 2.77
thanks for the help they are on the car an they are not drag shocks this is the first time I have bought anything off ebay without really knowing what I was getting need to be more careful they work fine on the softest setting, hard to believe thier any better then what I took off they really didn't have any more com resistance than what I took off. but on the car big diferance my rear shocks were gone bottoming out on everything. I will adjust another day an see what happens. seems to be what I would expect so far just a nice ride. new shox have a way of giving you that new car ride back
LT1Formula
Oct 8, 2015 08:34 PM
