Master cylinder and prop valves... lots of questions
Old Sep 28, 2003 | 10:40 PM
JPrevost's Avatar
Car: 91 Red Sled
Does anybody have or know of a place to find out the piston sizes in our master cylinders for both disc/drum and disc/disc for all years? Also, what is the prop valves set at?
As of right now I've got stock front brakes and aluminum drums in back. Car stops but it's scary, so I bought LS1 front brakes. Now I need to find information about our master cylinders to see if I need a new one. I don't know if I'll be able to find ls1 rear brakes before I install the ls1 fronts so obviously I'm going to run an adjustable prop valve either way.
Any and all experience, opinions, and thoughts welcome. Thanks in advance.
edit: I just found a site that spoke of a 10 lb residual valve. This is probably required if I got a disc brake master cylinder. So maybe I can just use the current master cyilnder until I get new rear brakes....any thoughts?
Oh yeah, and what is our pedal ratio?
J50 vs J65 cylinder sizes?
Old Sep 29, 2003 | 12:30 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The drum and Al caliper rear discs got the same MC with 15/16" bore. The Iron caliper rears got 1" bores. The LS1 fronts should work fine with rear drums and the drum prop valve, although an adj valve is always a good idea if you feel you need more power to the rears. Your drum MC should not have to be changed even when you goto rear discs.
Old Sep 29, 2003 | 01:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
https://www.thirdgen.org/techbb2/sho...aster+cylinder
Old Sep 29, 2003 | 04:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Arguably one of the best pieces of information that anyone ever dug up!
As to prop valves, I had read (somewhere, can't remember where) that on a 4-wheel-disc system, the prop valve doesn't do any proportioning... that it gives equal pressure to front and rear brakes. Anyone know if that's true?
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
