what exactly is this baer bump steer kit?
Old Sep 29, 2003 | 02:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what exactly is this baer bump steer kit that im hearing about?
where does it go and what does it replace?
Old Sep 29, 2003 | 05:51 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it is basicly an outer tie rod, that you can adjust, there are spacers on the part that connects to the spindle. so can re-adjust the angle of the tie rod, after you lower the car.
Old Sep 29, 2003 | 12:33 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ahh. thats simple enough.
does it come with diffrent height spacers or do you have to modify the one they give you to be "perfect" for your ride height?
Old Sep 29, 2003 | 01:08 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i really don't know, i don't have them, my car is still basicly stock ride height. agood2.8 runs the baer kit, he shoudl have the answer for you.
Old Sep 29, 2003 | 08:32 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Helpful info here: https://www.thirdgen.org/techbb2/sho...hreadid=202189
Old Sep 29, 2003 | 08:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
i read that other thread.....
im assuming it only comes with thoes spacers then....
you said it did eliminate all your bumpsteer, even though it isnt "ideal" right?
so i guess other spacers arnt needed..... *shrug*
Old Sep 29, 2003 | 08:44 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Look again- I used every spacer that came with the kit and it still did not get my angle low enough to set correct- HOWEVER- it did set things better than the stock tierod! MY angles are fine because MY suspension is so stiff I have barely any suspension travel (maybe 1" travel- most everyone elses cars move between 2-4" travel because of softer suspensions and/or V8 weight) YOUR car will vary based on ride height and weight.
My car is also lower than most any on this board. I have a lightweight V6 and can run lower without grounding out.
83 Crossfire TA
Jan 3, 2016 01:26 PM
tonys91rs
Oct 10, 2015 03:31 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
