I Need Help!!
I Need Help!!
Can someone pleeaase post a pic showing how the rear sway bar brackets mount to the frame?
My car does not have one and I have all the brackets but cannot figure out how the brack that hold the end links mount to the frame or body or where ever. I really have no clue, and have not been able to find pics anywhere in my searches.
Please help. I want to get this rear sway bar installed. Much thanks to everyone.
Sorry no picture, but my service manual shows the bracket held on by two bolts. The bracket should be about as far forward as the length of the swaybar end that comes off the bottom of the axle, at an upward angle. See if you can find the mounting holes toward the inside of the body. They could be plugged or covered with undercoating. Since the rear sway bar is listed as an option on some cars in the service manual, I would suspect the holes were drilled at the factory. Will try to get a rough measurement on where the mounting holes are, sometime today.
Car: check
Engine: check
Transmission: check
Re: I Need Help!!
https://www.thirdgen.org/techbb2/sho...hreadid=205173
RBob.
