panhard bar or diagnol link? strongest
I am going to install a 4 link suspension in my convertible. The primary use for the car will be street use but it will find an occasional weekend at the auto crosses. I want this car to corner like it is on rails, and have no play at all in the rear. I am trying to decide whether to use a panhard bar or a diagnol link. I would prefer to use the diagnol link, as its geometry will not result in bump steer, and I think they look a little cleaner. However I am not sure of the diagnol links strength in a corner with the car pulling near 1 g. If anyone has experience with this or is engineer minded I would thourghly appreciate comments or suggestions from anyone.
Thanks in advance.
Thanks in advance.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
all that work, you might consider a watts link.
i have been racking my brain, and if i am on the same boat as you, you will still have some bump steer with a diagnal link (i assume you mean 5link since you are adding that in.) a watts link would eliminate that completely. and is super trick
alot of the road racing stang guys convert to watts link for their lateral stability peice.
alot of the road racing stang guys convert to watts link for their lateral stability peice. Thread
