Question about going to rear disc brakes
Old Oct 27, 2003 | 12:12 AM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Alright I've been thinking about converting my drum brakes to disc, but in the tech article says it can't be done. Everyday I hear about someone changing over to discs. Whats the deal, can I do it? I really don't want to swap the entire rear end out. The one I have is already set up the way I want except for the disc brakes.
Old Oct 27, 2003 | 12:22 AM
85TransAm406's Avatar
Car: 1985 Trans Am
which tech article says you can't? Baer sells a kit specifically to do that, parking brake and all. There is also a tech article posted on converting your drum rear to LS1 F-body rear discs.
Old Oct 27, 2003 | 12:58 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
Get some 16" rims/tires if you dont have em already - My 15" rally's wouldn't fit over new rear disc brakes...
Old Oct 27, 2003 | 02:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stock brakes fit just fine inside stock 15" rims.
Old Oct 27, 2003 | 02:25 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
This is what I was talking about. It comes from How to upgrade you brakes written by Paul huryk.
" If you have a drum rear car,the rear must be swapped,since the drum rears do not have the proper backing plate to be switched."
Ok so simple stated can I buy a conversion kit off of Ebay and start putting together some disc brakes???
Old Oct 27, 2003 | 04:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're not afraid of modifying the drum flanges it can be done:
https://www.thirdgen.org/newdesign/t...reardisc.shtml
Old Oct 27, 2003 | 04:59 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Baer sells a convertion kit that bolts directly to the drum flange. Right now, thats the easiest and best way to go. I am personally waiting to see if Alloy develops a rear Wilwood setup to balance the front one he developed for Spohn. I am sick and tired of the rattles and chirps I get when I heat up my Iron caliper 10.5" brakes. They stop great- just rattle, clunk, twang, and squeak like a M.F.- I am sick of the noises they make.
Old Oct 27, 2003 | 09:59 PM
Thirtybird's Avatar
um... no... theres a lip inside the rim that hits the front face of the rear brake calipers that prevents the rim from seating against the hub. I wish it wasn't so, as it added $450 in tires to my new ride...
If you've already got 16's
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
