+35 Offset Wheels
Old Nov 12, 2003 | 08:21 PM
BadBird84's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.8l :(
Transmission: T-5 Five Speed
+35 Offset Wheels
Could I make rims with a +35 offset fit on my '84 Firebird? If so would I need spacers? And could anyone explain what +35 means and what problems arise when not using spacers? Thanks guys!!! I searched and couldn't find my exact answer
Old Jan 16, 2006 | 02:12 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
old i know but TTT
Old Jan 16, 2006 | 02:50 AM
JDubya18's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 LB9
Yes you would need spacers. +35 means its a 35 mm positive offset. Your tie rods would most likely rub on the rim if you get even get them on.
Old Jan 18, 2006 | 11:46 AM
TwiSSted's Avatar
Car: 95 Z28....87 T/A
You'd need in the neighborhood of a 2.75-3.00" spacer to get them on.
Old Jan 18, 2006 | 04:38 PM
JDubya18's Avatar
Engine: 305 LB9
Not quite that large, unless you meant 1.75-2" then that would be correct. Heres a informative website that will help you. http://www.skulte.com/adapterfaq.html
Old Jan 18, 2006 | 05:17 PM
TwiSSted's Avatar
According to the chart the 36mm Vette17x11 need a 1.25" spacer for a 3rd gen and the 50mm vette 17x11 needs a 2". I find that odd since a friend of mine has 36mm offset Vette grand sport wheels on his Typhoon and needed 1" spacers to fit them properly and I had 50mm offset polished Zr1s on mine and didn't need any.
Old Jan 18, 2006 | 08:10 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well ive done quite a bit of searching/learning and you can run a variety of spacers (some will fit better than others). rim diameter and width play a role. i contact someone selling a set of 19" 8.5 and 9.5 wide +35mm offset rims and they said i would need a 1.5" spacer. i have a 1 1/4" that i will try and use. if that doesnt work ill just take the measurements from there an buy different spacers.
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
