TRACTION help ?? out of ideas
Old Nov 17, 2003 | 05:12 PM
CAMARO THUNDER's Avatar
Which setup would be better for my iroc with 560#'s of TQ? Got all Billet LCA's + PHR, 50/50 drag shocks, front 90/10 struts with loaded springs, slicks, and 4:10 gears nothing has really seemed to help what do I do next ??
Lakewood Lift Bars ?
or
The billet LCA'S I have now with relocation brackets ?
THANKS
Old Nov 17, 2003 | 10:09 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
take off front swaybar....helped me out a lot.
Old Nov 17, 2003 | 10:35 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I say try the brackets before lift bars. There suppose to lower down your 60 foot times.
Maybe spohn tq arm with sub frame connectors (to tie the trans tunnel area into the rocker panel area).
Old Nov 19, 2003 | 09:46 AM
MdFormula350's Avatar
yeah i would get the brackets for the lower control arms, maybe try a rear passengers air bag also.
Old Nov 19, 2003 | 09:49 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what size slick are you running and how much more traction do you think you need? just a lil more bite or are you spinning them loose?
gta892000
Aug 11, 2019 11:16 AM
Numbah-1
Sep 12, 2015 08:57 PM
Djmathis123
Sep 8, 2015 08:42 PM
dbrochard
Sep 7, 2015 09:41 AM
