advantages of tubular a arms..
Old Nov 18, 2003 | 12:54 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
what are u some of the advantages of using tubular a arms? i know their lighter, but will they make the car handle better or what?
Old Nov 18, 2003 | 01:12 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
YES. Since they are lighter, they reduce unsprung weight, allowing the suspension to react faster. They are also quite a bit stronger than the stock pieces resulting in less deflection under load giving a quicker suspension response. The less the parts deflect, the more efficeint the suspension. If suspension parts deflect a lot, power to the ground at launch is absorbed as well as braking power at shut down. If you like to auto-x, you will definetly notice a difference in handling. On the street you'll probably notice a bit harsher ride, but it is soooo worth it.
For a-arms that you plan to use on the street, I'd stay away from chrome-moly. It is just too brittle and with all of the potholes and bad pavement in the world, a control arm failure at highway speeds could be disasterous.
grngryoutmyway
Oct 18, 2016 05:48 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
djmarch
Oct 2, 2015 10:41 PM
dinkrdsw
Theoretical and Street Racing
Sep 11, 2015 06:58 PM
